In ASA VPN Packets are decrypting, but not encrypting
mumazhar1
Dear All,
I am facing issue on my IPSec L2L VPN. However I seem to get the packets decrypted, but they will not encrypt. The sh crypto ipsec sa command output is below. I have check this out with my remote site, and verified all configs. Any suggestions will be appreciated.
local ident (addr/mask/prot/port): (67.159.51.10/255.255.255.255/0/0)
      remote ident (addr/mask/prot/port): (192.168.28.30/255.255.255.255/0/0)
      current_peer: xx.xx.xx.xx
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 33683, #pkts decrypt: 33683, #pkts verify: 33683
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
mumazhar1
Anybody have any idea about this issue..I am facing this issue first time..I had also verified both end config.
