Info on object-group knob
morningfalcon
Sorry if this is something obvious, but I was configuring some object groups today and noticed "knob" was an option after entering "object-group." I tried to find more info online but couldn't find anything. Could someone explain what "object-group knob" is and point me to some references on the subject?
Thank you,
~Nick
pieterh
sw(config)#object-group ?
   knob toggle a set of object-group knobs
sw(config)#object-group knob ?
   check-nested-entry-dup need to check nested entry duplication
   check-normal-entry-dup need to check normal entry duplication
=> the knob enables/disables checking for duplicate entries in a nested object-group or normal object-group
Thanks for replying. Could you explain when and how you would use that?
~Nick
sSiDs
i would like to know more too )
