insert an acl line between 2 others in an existing acl without removing acl
jerry.roy
Anyone know how to do this? I heard from Cisco and have actually done this once but don't remember the syntax.
I should be able to insert acl 15 between the lower 2.
Extended IP access list 198
10 permit ip any any
20 deny ip any any
TIA
steve.busby
Level 5
Level 5
Router(config)#ip access-list extended 198
Router(config-ext-nacl)#?
Ext Access List configuration commands:
<1-2147483647> Sequence Number
default Set a command to its defaults
deny Specify packets to reject
dynamic Specify a DYNAMIC list of PERMITs or DENYs
evaluate Evaluate an access list
exit Exit from access-list configuration mode
no Negate a command or set its defaults
permit Specify packets to forward
remark Access list entry comment
from there it's a simple matter of using the sequence number you want.
Router(config-ext-nacl)#15 permit/deny etc etc
Steve
