Installation of Prime Infrastructure 2.2.2
odenbreit.rene
Good day,
when I try do update my Cisco Prime Infrastructure 2.2.1 to 2.2.2 with update file "pi222-41.ubf" ,
I get the following error message during the upload process:
An error occurred while uploading file:
UBF with new version of update 'pi221_20150131_01' contains previous version '1.0.0' but the content of this version differs from the one installed before
Currently installed:
pi221_20150210_01.ubf
pi_2.2_device-pack_1-15.ubf
pi_2.2_device-pack_2-24.ubf
pi_2.2_device-pack_4-40.ubf
Thanks for your help
René
13 Replies 13
AFROJ AHMAD
Hi Rene,
Looks like another patch (pi221_pp_for_build_26-5.ubf  ) need to be installed first  before you move to
pi222-41.ubf.
I checked it in cisco.com , I couldn't find it . Please contact TAC  to publish this patch for you.
Thanks-
Afroz
***Ratings Encourages Contributors ****
pi222-41.ubf#sthash.Am7nFY0k.dpuf
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroz,
OK, I have opened a case based on your answer.
René
Hi Rene,
I have uploaded the ubf patch here..  hope issue would have been fixed by now but just in case..
sharing the update with you.
Thanks-
Afroz
Hi Afroz,
I have reinstall PI2.2.0 and install PI 2.2.1 V27.
In this moment, I restoring the Backup. Then I install PI2.2.2.
The procedure referred me the TAC.
TAC wrote:
[...] The only option we have is the following:
  • Reinstall PI 2.2
  • Install PI 2.2.1 version 27 maintenance release (attached to the case)
  • Restore the backup.
  • Install PI 2.2.2 patch. [...]
thanks for updating us
abakker03
I also experience this issue at a customer. Is there a possibility to resolve this?
Thx
you need to installed this patch "pi221_pp_for_build_26-5.ubf " before you upgrade
Thanks-
Afroz
I read that, but where can I download this update?
we don't see it available on cisco.com
will check , if I can find it for you.
thx
Hi ,
I have uploaded the file here::
Thanks-
Afroz
Thx for the file.
Not a problem..
***Do rate the useful post ***
