05-26-2008 06:18 AM
I followed the instructions on installing CVDM on my 6513 running (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF12a.
IP HTTP SERVER is enabled
Path is bootflash:
when typing sh ciscoview, i get this:
SW2_>sh ciscoview
File source:bootflash:
CVFILE SIZE(in bytes)
images/corp_message.gif 51
images/arrow_rt_04.gif 54
images/c6k.gif 9918
images/corner_dr_9.gif 53
images/corner_ur_8.gif 53
images/corporate_arrow.gif 64
images/cwhp_csco_logo.gif 3894
images/cwhp_filler2.gif 3672
images/cwhp_title_bg2.gif 246
images/cwhp_title_bot2.gif 1105
images/cwhp_title_filler3.gif 903
images/cwhp_title_top.gif 2179
images/shim.gif 43
images/splashscreen.gif 31557
cwhp_global_ns.css 6697
cvdmpage.js 14094
applet.html 8070
LZMA.jar 6426
cwhp_global_ns_sol.css 6697
error.html 597
cvdm-c6500-1.1.sgz 2657544
diceloader.jar 63656
So everything seems to be fine, yet when I type in the url suggested, I get page cannot be displayed.
Everything is there, and the client im using to try to connect to the CVDM is on the same subnet, I can SSH to the switch directly.
05-26-2008 09:27 AM
CVDM does not work with 12.2(18)SXF code. There is a patch available from the TAC for bug CSCsc10956 that should fix this, but you should be aware that CVDM is dead. There is no new development or bug fixes. Customers are being urged to move to CiscoWorks LAN Management Solution which contains host-based CiscoView.
05-26-2008 11:38 AM
thanks !
