Instance OIDs for OSPF
gaurav_saxena
Level 3
Level 3
How can i get Instance OIDs for object identifiers in OSPF. for example..for
object identifier = 1.3.6.1.2.1.14.2.1.4
what will be the instance OID?? My NMS tool required that to monitor different OIDs
steve.busby
Level 10
Level 10
The easiest way to get the current instance number(s) is to do an snmpwalk against the device(s).
From any *nix system (with SNMP tools loaded):
snmpwalk -v2c -c 1.3.6.1.2.1.14.2.1.4 > device.txt
Steve
funsok217
Community Member
Download Solarwinds and use the SNMP walk menu to get the different instance oids you want.
