Integrating NMS with RADIUS server with EAP-TLS Protocol
vmurugan
I am trying to authenticate my server(running an NMS- Cisco Prime Infrastructure) with an Cisco ISE with EAP-TLS protocol.
I am seeing "11036 The Message-Authenticator RADIUS attribute is invalid " in the ISE when the ACCESS-REQUEST is sent from NMSServer to ISE. The RADIUS shared secret key is same in both the NMS server and the ISE server .
Is the some java samples for Message authenticator attribute which I can refer. I think, I am missing something in Message authenticator attribute.
I am able to authenticate successfully with PAP and CHAP. I am seeing this issue only in EAP-TLS. Anyone have tried supporting their NMS remote authentication with RADIUS(EAP-TLS) ?
Any pointers or suggestions to overcome this ?
Vasanth
0 Replies 0
