INTER VLAN ROUTING
balde
hello everyone !!!
i've have successfully configured LACP etherchannel on both layer 3 switches, i have assigned them both ip address of every vlan, i've enabled IP ROUTING and NO SWITCH PORT on the interfaces connected to the router. I have also configured OSPF but i still cannot PING from the Admin laptop (VLAN Gestion) to other VLANs but the opposite works...does anyone know what might be the problem ?
please i need HELP !!!
hostname layer3-1
ip routing
no ip domain-lookup
spanning-tree mode pvst
interface Port-channel2
 switchport access vlan 99
 switchport trunk native vlan 99
 switchport mode trunk
interface Port-channel3
interface FastEthernet0/1
 no switchport
 ip address 172.16.48.1 255.255.255.248
 duplex auto
 speed auto
interface FastEthernet0/19
 channel-protocol lacp
 channel-group 2 mode active
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
 channel-group 3 mode active
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 mac-address 00e0.f9ae.ec01
 ip address 172.16.57.123 255.255.255.128
interface Vlan20
 mac-address 00e0.f9ae.ec02
 ip address 172.16.56.251 255.255.255.0
interface Vlan30
 mac-address 00e0.f9ae.ec03
 ip address 172.16.57.136 255.255.255.192
router ospf 1
 router-id 4.4.4.4
 log-adjacency-changes
 redistribute static
 redistribute connected
 network 172.16.56.0 0.0.0.255 area 0
 network 172.16.57.0 0.0.0.127 area 0
 network 172.16.57.128 0.0.0.63 area 0
 network 172.16.48.0 0.0.0.7 area 1
ip classless
ip route 172.16.57.0 255.255.255.128 Vlan10
ip route 172.16.57.128 255.255.255.128 Vlan30
ip flow-export version 9
layer3-1(config)#
hostname layer3-2
ip routing
no ip domain-lookup
interface Port-channel4
no switchport
ip address 172.16.48.3 255.255.255.248
duplex auto
speed auto
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
channel-group 4 mode active
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 00d0.9704.b901
ip address 172.16.57.124 255.255.255.128
interface Vlan20
mac-address 00d0.9704.b902
ip address 172.16.56.252 255.255.255.0
interface Vlan30
mac-address 00d0.9704.b903
ip address 172.16.57.137 255.255.255.192
router ospf 1
router-id 3.3.3.3
neighbor 172.16.48.4
ip classless
line con 0
line aux 0
line vty 0 4
login
End
layer3-2(config)#
luis_cordova
Hi @balde ,
I see that the two L3 have the same network, being that when entering the command no switchport those interfaces are left with a router port.
If you can, create a new network and assign different networks. One for the connection of a switch with his router and another one for the connection of the other switch with his router.
Now, if you must use a single network for the two switches, I recommend creating a communication vlan, which would make the two switches, through SVI, belong to the same network (same number of vlan). For this, you must configure subinterfaces in the two routers, encapsulated with the vlan number of the communication vlan.
I hope you can understand me.
luis_cordova
Hi @balde ,
thank you a lot !!!
I changed the L3 switches interfaces from routing to switch with the command swithcport then the following commands
switchport trunk allowed vlan 10,20,30
now i the inter vlan routing problem is solved
Thanks angain !!!
