interface snmp index persistency
mfis90
Regarding SNMP, on the same hardware model, same software version the following command returns different values:
sh snmp mib ifmib ifindex gigabitEthernet 2/0/1
GigabitEthernet2/0/1 Ifindex = 53
GigabitEthernet2/0/1 Ifindex = 249
is there a way to configure index persistence on the platform?
this is on C9300-24T 17.13.01 CAT9K_IOSXE
The reason for this question is because my software only supports static configuration of indexes.
Mark Elsen
           - Try : snmp ifmib ifindex persist
                     (in configuration mode)
  M.
mfis90
do you know why is this command used? or can you explain?
