01-05-2012 09:24 AM
I am trying to populate the LMS 4.1 components to ACS. Can you anyone advise me on how do this? Thank you.
Solved! Go to Solution.
01-05-2012 11:29 AM
Note that LMS 4.x only uses ACS for Authentication. Authorization now needs to be set up locally on LMS. Reference here.
That said, you can have a look at this document, written from the perspective of LMS 3.2 and ACS 4.1, for the bits that need to be done on the ACS server.
01-05-2012 11:29 AM
01-05-2012 11:48 AM
Thank you very much for the info. this is what I am looking for.
