internal netflow collector not showing peaks as expected
hmc250000
we are using scrutinizer as our internal collector. I was comparing graphs between our collector and utilization reports from our ISP for the same circuit however graphs from our collector shows much lower peaks. Could this have anything to do with the intervals or sample sizes possibly being different? How do you configure netflow on cisco equipment to always show the peaks and averages? I've tried changing the settings in the collector but no luck.
 This can be related to the interval on the ISP, they can be using SNMP instead netflow. The default interval on cisco device is 30 minutes but you can change it.
