IOS Distribution to 3750 Stack
john.wright
Level 3
Level 3
When I try to push code out to a 3750 stack from the software repository of LMS 2.6 CW I get a msg that says among other things that I need a TAR file in order to load a stack. However when I try to download files from the image source cisco.com the only thing I see are BIN files.
Joe Clarke
You want to download the images marked "WITH WEB BASED DEV MGR". Those are .tar images. I just tested this in RME 4.0.6, and it is working.
Joe Clarke
