IOS Upgrade Record in Cisco Works?
ahmad82pkn
Level 3
Level 3
Hi, I am little new to cisco works, and unable to find log that can show me which devices had IOS upgrade in last 1 month or year etc.
is it possible to check from cisco works? if yes, where exactly.
thanx.
Marvin Rhoads
There is a report called "Change Audit Report". Among other things, it will tell you:
Software Management—The Software Modification History report is displayed.
This window shows the changed software image details.
I'm not sure if it will tell you if the software was upgraded "manually" (i.e., not as part of an LMS-initiated job).
Have a look at this link and see if it does what you're looking for.
Marvin Rhoads
i found the option But looks like i didnt upgraded any IOS, since its not showing me any result, may be i didnt upgrade any thing after adding them in cisco works, i ll check on this.
thank you
