ios upgrade
cisco steps
I am currently using ios :
IOS (tm) 3600 Software (C3660-IS-M), Version 12.1(17), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
there is a bug on this one as it is old... can someone suggest the latest "IOS version" I can use
Richard Burts
You have not told us which 3600 router it is and you have not told us how much memory and how much flash it has, all of which help determine what release would work for you. But if the question is what is the latest version of IOS then the Feature Navigator on the Cisco web site says that this is the IOS:
c3640-i-mz.124-23.bin
note that this requires 64 MB of memory and 16 MB of flash.
Rick
Rick
rick,
here is the info.. one thing that is critical to the business is DLSW..
Compiled Tue 03-Sep-02 19:05 by kellythw
Image text-base: 0x60008950, data-base: 0x60E40000
ROM: System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
router uptime is 6 years, 26 weeks, 21 hours, 25 minutes
System returned to ROM by reload
System restarted at 11:23:43 EDST Fri Sep 20 2002
System image file is "flash:c3660-is-mz.121-17.bin"
cisco c3660 (R527x) processor (revision C0) with 92160K/6144K bytes of memory.
Processor board ID JMX0636L974
R527x CPU at 225Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
3660 Chassis type: ENTERPRISE
1 Ethernet/IEEE 802.3 interface(s)
2 FastEthernet/IEEE 802.3 interface(s)
6 Serial network interface(s)
24 Low-speed serial(sync/async) network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
16384K bytes of processor board PCMCIA Slot0 flash (Read/Write)
Configuration register is 0x2101
The additional information allows me to offer you a better suggestion. It shows that you are running the IP PLUS feature set which includes support for DLSW+ and it shows how much memory and flash you have. I checked the Feature Navigator on the Cisco site and it shows that the IP PLUS feature set in the 12.3 and 12.4 releases require more flash than the 16MB that you have. So the most recent release that will run on your existing hardware using the IP PLUS feature set would be:
c3660-is-mz.122-46a.bin
which is the most recent release in version 12.2.
Rick
Rick
rick , Thanks for all the info.how did you figure out from the show version that I am running dlsw plus with IP plus feature. one more question how do you check the cisco navigator and how did you come w/ the results. I will love to be able to find it myself next time I need ios update
Thanks again Rick
