IOS-XR EEM LLDP event help
sreenivasgajula
Hello everyone,
I'm trying to migrate a working eem script on IOS to IOS-XR. Basically want to rename interface description whenever lldp neighbor changes.
Here's the working script on IOS/IOS-XE device:
event manager applet AUTO_UPDATE_NEIGHBOR
event neighbor-discovery interface regexp .*GigabitEthernet[0-9]/[0-9,/]+$ lldp add
action 1.0 cli command "en"
action 1.1 cli command "sh int desc | i $_nd_short_local_intf_name"
action 1.2 regexp "[A-Z][A-Z][A-Z][A-Z][-][M][O][E][-][0-9][0-9][-][P]" "$_cli_result" _ringID
action 1.3 if $_regexp_result eq "1"
action 1.4 string trimright "$_nd_lldp_system_name" ".mgmt.upnfiber.com"
action 1.5 set underscore "_"
action 1.6 cli command "enable"
action 1.7 cli command "conf t"
action 1.8 cli command "interface $_nd_local_intf_name"
action 1.9 cli command "description P2P-$_ringID$underscore$_nd_lldp_system_name"
action 2.0 cli command "end"
action 2.1 cli command "exit"
action 2.2 else
action 2.3 regexp "[A-Z][A-Z][A-Z][A-Z][-][M][O][E][-][0-9][0-9]" "$_cli_result" _ringID
action 2.4 if $_regexp_result eq "1"
action 2.5 string trimright "$_nd_lldp_system_name" ".mgmt.upnfiber.com"
action 2.6 set underscore "_"
action 2.7 cli command "enable"
action 2.8 cli command "conf t"
action 2.9 cli command "interface $_nd_local_intf_name"
action 3.0 cli command "description P2P-$_ringID$underscore$_nd_lldp_system_name"
action 3.1 cli command "end"
action 3.2 cli command "exit"
action 3.3 end
action 3.4 end
I looked at some posts on on how to use EEM on IOS-XR and I was able to run the example provided. Based on some trial and error, I think the first line in a tcl script shown below is incorrect and I tried tweaking it quite a bit with no luck.
::cisco::eem::event_register_neighbhor_discovery interface regexp .*GigabitEthernet[0-9]/[0-9,/]+$ lldp add maxrun 90
sreenivasgajula
I'm trying this on NCS540(XR 7.3.1). Looking at an old Cisco live presentation(screenshot attached), neighbor discovery events were not supported in XR back in 2014, unable to new information on it.
