IOS-XR EEM Scripting
frankieng
Visitor
I would like to use the EEM script to do some automation in router.
My scripting want to monitor the te0/1/0/0, Output Data Rate has amount of bps, then open the cli for some interface configuration.
after apply the testing.tcl file, commit the ASR 9006 router return:
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
event manager policy testing.tcl username col persist-time 3600 type user
!!% Embedded Event Manager configuration: failed to retrieve intermediate registration result for policy testing.tcl
What is problem? attached the TCL file
RP/0/RSP1/CPU0:Har3-C9K#show event manager environment
No.  Name                          Value
1    _config_cmd1                  interface Te0/1/0/1.10
2    _config_cmd2                  description testing_interface
5 Replies 5
Joe Clarke
I think you're missing the modifier keywords in your event registration line:
::cisco::eem::event_register_stat name ifstats-datarate modifier_1 Te0/1/0/0 modifier_2 OutputDataRate entry_op gt 3600000 exit_comb and exit op ne 3600000 exit_time_sec 1800
Thank you for your information.
Change the scripting, but still failure
Do the TCL file require store other location?
or require user library for
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
C9K#show event manager directory user library
not configured
C9K#show event manager directory user policy
disk0:/
I noticed some other problems with the line.  Try this one:
::cisco::eem::event_register_stat name ifstats-datarate modifier_1 Te0/1/0/0 modifier_2 OutputDataRate entry_op gt entry_val 3600000 exit_comb and exit_op ne exit_val 3600000 exit_time_sec 1800
Tried but result failure
Try this script.
