%IOSXE-3-PLATFORM: 1 process kernel: ci_dump_write: task=SIF SR, write error: attempted=52 returned=-32.
RALISPO
Hello everyone!
I need some help with this issue I'm receiving in a Catalyst 3600, Version 16.12.4:
Does anyone have any idea what this is, and if is there a fix?
Thanks in advance!
14 Replies 14
Leo Laohoo
How often is that error message appearing in the logs?
Hi Leo, thanks for the message!
Actually it's random, the error sometimes take a long time until it starts over, and then it's repetitive for a while. It's really weird.
Upgrade the firmware to 16.12.5b.
16.12.4 is one of the buggiest software I have ever used and I have >4 TAC cases to prove my claim.
I didn't know that, about 16.12.4 being so bugged. Ok, will do that, probably will get fixed. Thanks a lot Leo! Best regards.
Mohsin Alam
Can you check your CPU utilization, is it normal ?
## Make sure to mark post as helpful, If it resolved your issue. ##
Hi mohsiala, thanks for the message!
Sure, here goes an output, but apparently it's ok:
CPU utilization for five seconds: 6%/0%; one minute: 6%; five minutes: 5%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
98 2521557 471219 5351 0.87% 0.38% 0.36% 0 Crimson flush tr
452 3206779 6495359 493 0.87% 0.74% 0.76% 0 SISF Main Thread
451 2594170 4099029 632 0.79% 0.61% 0.62% 0 SISF Switcher Th
3 452 159 2842 0.31% 0.47% 0.13% 2 SSH Process
222 817554 1089208 750 0.23% 0.16% 0.16% 0 Spanning Tree
125 1640088 32388045 50 0.23% 0.28% 0.27% 0 L2 LISP Punt Pro
349 595194 16493707 36 0.15% 0.09% 0.08% 0 MMON MENG
211 854349 16316302 52 0.15% 0.14% 0.15% 0 IP ARP Retry Age
121 546128 5277044 103 0.15% 0.17% 0.10% 0 IOSXE-RP Punt Se
392 194456 2722615 71 0.15% 0.02% 0.01% 0 PM Callback
74 496315 1515284 327 0.15% 0.10% 0.09% 0 Net Background
224 754077 5348217 140 0.07% 0.12% 0.13% 0 UDLD
348 668704 8241696 81 0.07% 0.11% 0.11% 0 MMA DP TIMER
443 252430 614344 410 0.07% 0.11% 0.06% 0 PDU DISPATCHER
205 210577 216482 972 0.07% 0.03% 0.02% 0 CDP Protocol
157 189540 131967 1436 0.07% 0.04% 0.02% 0 FEP background p
146 291498 386026 755 0.07% 0.05% 0.05% 0 PLFM-MGR IPC pro
444 1800075 885718 2032 0.07% 0.86% 0.43% 0 SNMP ENGINE
158 105828 131967 801 0.07% 0.01% 0.00% 0 Thermal backgrou
66 28296 275789 102 0.07% 0.00% 0.00% 0 SASRcvWQ
81 1428103 2283266 625 0.07% 0.23% 0.26% 0 IOSD ipc task
195 665362 8241711 80 0.07% 0.12% 0.13% 0 VRRS Main thread
316 668906 8241667 81 0.07% 0.10% 0.10% 0 MMA DB TIMER
449 344385 2633477 130 0.07% 0.06% 0.07% 0 ONEP Network Ele
24 3879 105568 36 0.00% 0.00% 0.00% 0 IPC Service NonC
23 318 8799 36 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
22 1 1 1000 0.00% 0.00% 0.00% 0 Platform appsess
21 25267 515324 49 0.00% 0.00% 0.00% 0 IPC Mcast Pendin
25 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
26 25924 515324 50 0.00% 0.00% 0.00% 0 IPC Periodic Tim
20 3967 105568 37 0.00% 0.00% 0.00% 0 IPC Event Notifi
32 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat TX Cont
33 2364 52788 44 0.00% 0.00% 0.00% 0 IPC Keep Alive M
balaji.bandi
is this stack ? or standalone ? how long was the uptime ?  is this error after upgrade ?
try hard reboot and check - is this fix the issue.
BB
Hi balaji.bandi, thanks for the message!
The uptime is 6 days, it's a standalone switch, I'm not sure if this started after upgrade, but as this switch has been recently rebooted, I still didn't get any other message, but I'm still monitoring as this has been over and over repetitive.
After reboot if you not seeing the issue, it may be gradually pile up, suggest upgrading to the latest stable code when you get a chance or maintenance window.
BB
Definitely I'll suggest the upgrade of the firmware, I'm sure that only with a reboot it will eventually comes back.. Thanks for the help balaji! Best regards.
Mark Elsen
 - You may try the advisory release, check if that helps :
              https://software.cisco.com/download/home/286309930/type/282046477/release/Gibraltar-16.12.5b
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi marce1000, thanks for the message!
Yes, we actually took it in consideration to make an upgrade, we're just monitoring after a recent reboot, so far so good, but I'm not sure that this situation is fixed for good, so if it comes back I'll suggest the upgrade.
Mohsin Alam
yeah if it's a one time occurrence then monitor the device and upgrade to a safe harbor !
That's probably the best thing to do, the firmware upgrade. I'm pretty sure it will fix the issue. Thank you mohsiala! Best regards.
