Hello everybody.
I hope everything goes well for you.
I have a problem with IP management on our Devices.
we assigned IP on physical interfaces that are the gateway of our users in branches. so behind the physical interface are a lot of users, devices, and so on. I want to harden our devices and base on the cisco harden documents we need to assign IP managment on a loopback interface because Loopback interfaces are always up, whereas physical interfaces can change state, and the interface can potentially not be accessible.
Unfortunately, we have some limitations such as
1- behind the physical interface ( earlier management ) we have a lot of devices (switches, computers,..) that should have a gatway.
2- when we assign an IP address on the loopback interface we lose our connection behind the physical interface that is gataway.
Could you please give me your advice?
Thank you.
Mehrab
