IP SLA and Loopback 0 interface
zopechowski
Community Member
Greetings from Poland,
is there any chance to use virtual interface (i.e. loopback 0) for the IP SLA feature of cisco routers? I would like to set a public ip address for this interface and would like to test www, dns and my core network.
Thanks in advanced,
ZO
Joe Clarke
If you mean source the IP SLA probes from a loopback interface, this is certainly possible. For example, if you want to measure the latency between the device, and a WWW server, 10.1.1.1, and your loopback IP is 1.1.1.1:
ip sla 113
http get http://10.1.1.1/ source-ip 1.1.1.1
You can even specify a source interface name instead of an IP address.
