LAN DESIGN
wladimirpausin
Hi, I am working in a network design for a future implementation. I have to select two switches as a core, these must be conected with each other. On the access must be 7 switches which suport Gigabit and have 4SFP each one, on the distribution switches I must select 3 switches which support 10/100 MBPS and POE.
I have to consider just Cisco switches and 3COM.
All switches preferible must be conected as redundant in one stack.
I am looking forward for any suggestion.
ivillegas
Level 11
Level 11
I think for core Catalyst 6500 series, for access Catalyst 4900 series and for distribution Catalyst 3750 series will be best considering design for future implementation.
Following link may help you
http://www.cisco.com/en/US/products/hw/switches/index.html
