IP Sla monitor operations - with multiple IPs reachability
Sureshkumar B
We have two ISP routers connected to two different ISP, and on routers lan interface we are running HSRP, so one router will be active at a time and traffic will be forwarded to that router A and respective ISP. Also we notice when router A next hop is unreachable and same ethernet WAN interface is showing UP, therefore HSRP is not failing back.
To avoid the above situation, we configured IP SLA as like below
int fa 0/0 (LAN)
standby 1 track 1 shutdown
ip sla 1
icmp-echo x.x.x.x source-ip y.y.y.y
ip sla schedule 1 life forever start-time now
Where x.x.x.x is next hop IP (ISP end) and y.y.y.y is fa 0/1 interface IP (Fa0/1)
This solution worked sucessfully, primary router HSRP went to standby and secondary router came ACTIVE.
Here sometimes we are face issue in internet reachablility but my next hop will be UP. Due this HSRP was not falling back.
To avoid this scenario, we need to monitor reachability of next hop as well as internet, so please suggest any options there.
Rejohn Cuares
Level 4
Level 4
You can use the track's boolean OR operation.
track 10 ip sla 306 reachability
track 11 ip sla 307 reachability
track 30 list boolean or
object 10
object 11
track 300 ip sla 300 reachability
track 301 ip sla 301 reachability
ip sla 300  !!!! To track Internet host
icmp-echo 4.2.2.2 source-interface F0/0
ip sla schedule 300 life forever start-time now
ip sla 301  !!!! To track ISP next hop
icmp-echo 10.2.0.202 source-interface F0/0
ip sla schedule 301 life forever start-time now
int F0/0
standby 1 track 30 shutdown
Please rate replies and mark question as "answered" if applicable.
Rejohn Cuares
Level 4
Level 4
object 10
object 11
int F0/0
