IP SLA - one-way delay
ChrisNewnham_
For those SLA probes that support one-way delay statistics, e.g. UDP Jitter, does the one-way delay measurement always require a Cisco endpoint using ip sla responder feature?
Thanks!
18 Replies 18
Joseph W. Doherty
Hmm, unsure jitter is truly a one way measurement, although it's easy to think it is.
As far as requiring a SLA responder to measure jitter, unsure that's true too.  The biggest feature of a SLA responder is it tells the sender how long it took to respond, so that time is NOT attributed to the network.
Anyway, for measuring jitter in just one direction, I can see it being done with packets carrying additional information, which possibly many applications don't provide.  If they don't, a sender could figure jitter for the round trip, independent of packet contents, but it wouldn't be able to truly tell either direction's jitter or receiver's impact to measurements.
-For udp jitter you need responders
-For icmp jitter the responder is optional' but it recommends to config it.
MHM
That didn't actually answer my question
I know that UDP Jitter requires responders, my question does the one-way delay measurement require a Cisco responder (UDP Jitter itself does not itself require a Cisco responder).
Yes friend  I answer you
Udp jitter (one way or other) need responders.
MHM
Can you please specify if you mean a Cisco responder, or a standard IP/application device that is listening on UDP Port 7
UDP Jitter for VOIP requires a Cisco responder
UDP Jitter requires any responder (Cisco or not) ---> this is the one I am talking about
Wait I think I found something help you' let me check it in lab'
Udp use control to make responder know the udp port it use.
There is a note that this control if disable ypu dont need responder.
But let me check it
MHM
control is disable and the responder is not config
the control is disable and the responder is only config with ipaddress and port (no ip sla responder)
it work
so you need either
1-enable control and config ip sla responder
or
2-disable control (in sender) and config
#ip sla responder udp-echo ipaddress 100.0.0.2 port 1000
MHM
ChrisNewnham_
Thanks MHM, but just to bring it back to the original question
For the UDP Jitter SLA, can a non-Cisco responder (which are supported for this SLA) be used to provide one-way delay statistics?
For the UDP Jitter SLA, can a non-Cisco responder (which are supported for this SLA)? It support what can you elaborate.
MHM
One-way delay statistics.
if it non-cisco how is support IP SLA UDP jitter, non-cisco not support to be sender or responder.
and if you use cisco then you need as I mention above.
MHM
So what that says is, "you cannot configure an IP SLA responder on a non-Cisco device".
It does not say, you can't use a non-Cisco device as a responder for this probe.
This document says UDP Jitter for VOIP requires Cisco Endpoints, but UDP Jitter does not.
https://www.cisco.com/en/US/technologies/tk648/tk362/tk920/technologies_qas0900aecd8017bd5a.html
Where did that screenshot come from, a book perhaps? It doesn't even mention UDP Jitter for VOIP only UDP Jitter, so I wonder if it is quite old.
Friend
I dont have much to say after all above.
Udp jitter need udp port which work with control enable or disable' and both need cisco device to config.
Have  a nice day
MHM
