IP SLA responder on Catalyst 2960S stacked
leeflight
I have a pair of switches stacked:
Switch Ports Model                          SW Version          SW Image
     1    52      WS-C2960S-48FPS-L  15.0(1)SE             C2960S-UNIVERSALK9-M
*    2    52      WS-C2960S-48FPS-L  15.0(1)SE             C2960S-UNIVERSALK9-M
When I try to enable ip sla responder on the stack I get:
%SYS-3-HARIKARI: Process IP SLAs Responder top-level routine exited
I have been able to find a bug in the toolkit. Should ip sla responder be supported on the
stack as above?
Lee Flight
6 Replies 6
leeflight
Also seen on the same hardware running
c2960s-universalk9-mz.122-58.SE2
Lee Flight
The problem also exists in:
on a standalone switch (not part of any stack).
However
c2960s-universalk9-mz.122-55.SE3
on a standalone switch is fine and works as expected.
leeflight
Also broken in
WS-C2960S-48FPS-L  15.0(1)SE1            C2960S-UNIVERSALK9-M
standalone or stacked.
Doesn't work in 15.0(1)SE2 either.
Mar 24 12:34:33 PDT: %SYS-3-HARIKARI: Process IP SLAs Responder top-level routine exited
Mar 25 09:27:20 PDT: %SYS-3-HARIKARI: Process IP SLAs XOS Event Processor top-level routine exited
Still broken in 15.0(1)SE3.
Oct 25 18:46:26 PDT: %SYS-3-HARIKARI: Process IP SLAs Responder top-level routine exited
I can confirm 15.0(1)SE3 still has the bug.
I just tested 15.0(2)SE3 released yesterday in a lab environment and....... (drum roll)..... no more HARIKARI . Hardware were two WS-C2960S-48FPS-L unstacked (one of them with installed stacking module though)
Haven't tried the earlier 15.0(2) (i.e. SE, SE1 and SE2) releases - maybe they work too.
