Multi-line command problems
jedavis
Level 7
Level 7
I am trying to add an motd banner to a configuration template in template center.  When I add it I get the following error on the import:
Template import Failed. Unable to parse the XML file.Please ensure that the XML file is complaint to the schema.
I went to the config manual and copied the multi-line command example exactly as shown and added it to my template:
<MLTCMD> banner login "Welcome to
Cisco Prime LMS - you are using
Multi-line commands" </MLTCMD>
I still get the import error.  I have never been able to get multi-line commands to work in any version of LMS.  Is this a known issue?  Is there a fix?
-Jeff
Sorry for the delay.  I have been playing catch up since returning from CiscoLive!.  I found the bug.  The variable expansion was not being done on the full multi-line command.  I have a working patch in my lab.  If you open a TAC service request using the Open TAC Service Request link in the actions panel of this thread, your engineer can contact me for the patch.
10 Replies 10
Joe Clarke
The ability to import templates with multi-line support was not added until LMS 4.1.  You also have to use < and > instead of < and > as the MLTCMD tag is embedded into XML and not part of the XML itself.  Here's an example from the SCH template:
crypto ca authenticate cisco<R><MLTCMD>-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
MIIGNDCCBRygAwIBAgIQWrQ6b86cjzk7c3BoO7KqETANBgkqhkiG9w0BAQUFADCBtTELMA
kGA1UEBhMCVVMxFzAVBgNVBAoTDlZlcmlTaWduLCBJbmMuMR8wHQYDVQQLExZWZXJpU2ln
biBUcnVzdCBOZXR3b3JrMTswOQYDVQQLEzJUZXJtcyBvZiB1c2UgYXQgaHR0cHM6Ly93d3
cudmVyaXNpZ24uY29tL3JwYSAoYykxMDEvMC0GA1UEAxMmVmVyaVNpZ24gQ2xhc3MgMyBT
ZWN1cmUgU2VydmVyIENBIC0gRzMwHhcNMTAxMjEyMDAwMDAwWhcNMTExMjEyMjM1OTU5Wj
B5MQswCQYDVQQGEwJVUzETMBEGA1UECBMKQ2FsaWZvcm5pYTERMA8GA1UEBxQIU2FuIEpv
c2UxFjAUBgNVBAoUDUNpc2NvIFN5c3RlbXMxEDAOBgNVBAsUB0FUUy1BV1MxGDAWBgNVBA
MUD3Rvb2xzLmNpc2NvLmNvbTCBnzANBgkqhkiG9w0BAQEFAAOBjQAwgYkCgYEAzouIOWzv
djJlWDPYk55kyhbnxxYv6S1eZ0blZ09XdipLrf+YluZ8++ux3Ld6lr6QnVdI1/AYYA2K5F
4+2D+ZJUwLnaQW1QYIzbmeVhbdcAa7IwuR+P8eMUaetOUAdC641QvMXtpZQ5I0WdTS2IV/
O7A3H1V3QInS2+0xnnehTT8CAwEAAaOCAv0wggL5MIIBKAYDVR0RBIIBHzCCARuCD3Rvb2
xzLmNpc2NvLmNvbYIOYXBwcy5jaXNjby5jb22CEHRvb2xzMS5jaXNjby5jb22CEHRvb2xz
Mi5jaXNjby5jb22CEHRvb2xzOS5jaXNjby5jb22CFHRvb2xzLXdhczUuY2lzY28uY29tgh
R0b29scy13YXM2LmNpc2NvLmNvbYIUdG9vbHMtd2FzNy5jaXNjby5jb22CFXRvb2xzLXRl
c3QzLmNpc2NvLmNvbYIVdG9vbHMtdGVzdDQuY2lzY28uY29tghp0b29scy10ZXN0MS13YX
M3LmNpc2NvLmNvbYIadG9vbHMyLXRlc3Qtd2FzNi5jaXNjby5jb22CGnRvb2xzMi10ZXN0
LXdhczcuY2lzY28uY29tMAkGA1UdEwQCMAAwCwYDVR0PBAQDAgWgMEUGA1UdHwQ+MDwwOq
A4oDaGNGh0dHA6Ly9TVlJTZWN1cmUtRzMtY3JsLnZlcmlzaWduLmNvbS9TVlJTZWN1cmVH
My5jcmwwRAYDVR0gBD0wOzA5BgtghkgBhvhFAQcXAzAqMCgGCCsGAQUFBwIBFhxodHRwcz
ovL3d3dy52ZXJpc2lnbi5jb20vcnBhMB0GA1UdJQQWMBQGCCsGAQUFBwMBBggrBgEFBQcD
AjAfBgNVHSMEGDAWgBQNRFwWU0TBgn4dIKsl9AFj2L55pTB2BggrBgEFBQcBAQRqMGgwJA
YIKwYBBQUHMAGGGGh0dHA6Ly9vY3NwLnZlcmlzaWduLmNvbTBABggrBgEFBQcwAoY0aHR0
cDovL1NWUlNlY3VyZS1HMy1haWEudmVyaXNpZ24uY29tL1NWUlNlY3VyZUczLmNlcjBuBg
grBgEFBQcBDARiMGChXqBcMFowWDBWFglpbWFnZS9naWYwITAfMAcGBSsOAwIaBBRLa7ko
lgYMu9BSOJsprEsHiyEFGDAmFiRodHRwOi8vbG9nby52ZXJpc2lnbi5jb20vdnNsb2dvMS
5naWYwDQYJKoZIhvcNAQEFBQADggEBAIskILQZDB7FjTQoqyu3LlSLF1yl+6bdhgXOJFmC
9Zdl2g/91hHpKVs3CYPhGcTef8ehVwa3CN4Iuvatvpbf+u1/xayQ8kppjQ3G2Akv9QofB9
dbMmnd6r0KmcLNy7Bxn6L96Fu2XbAzoHQRYrLIMr4F4A+A1yDSjKO6DbIQQzT8vFHtboI0
HjoVGrKEH5+KqB1RGYwfJDUjdfQoifFHW78Ax/NbeUd8i4/HMbM3zT3TW8oGlrUJaFiFMJ
wDTUspBzYYKPvDOcl+uRFSeeoOJsB3L6U2ckvqQOzSJ4vZ/Jh6B0UBpbjgL3Tm8PraGikU
CCFlA7a9V0JX0dgLdRpWgUI=
MIIE0DCCBDmgAwIBAgIQJQzo4DBhLp8rifcFTXz4/TANBgkqhkiG9w0BAQUFADBfMQswCQ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MIIF7DCCBNSgAwIBAgIQbsx6pacDIAm4zrz06VLUkTANBgkqhkiG9w0BAQUFADCByjELMA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=
END OF INPUT</MLTCMD><R>yes
Joe,
The user guide for RME 4.0.5 in LMS 2.6 discusses in the netconfig section.  I could never get this to work.  Perhaps this is why.
I did discover that using the < > entities works from the schema description.  What I ended up doing was enclosing the CLI in
</p><p>--- cli commands ---</p><p>
This of course prevents the enclosed text from being parsed and allows me to use the <> notation.
However, now I am stuck with another problem while trying to insert a variable into the banner:
This is the statement within the CDATA tag:
banner motd "
${snmplocation}
* UNAUTHORIZED blah blah....
* ....blah blah!
And deploying this results in the ${snmplocation} variable getting expanded outside of (before) the block.  The job output looks like this:
Switch(config-archive-log-cfg)# ! MOTD
Switch(config-archive-log-cfg)#Expanded Snmplocation Variable
% Invalid input detected at '^' marker.
HHCS010(config-archive-log-cfg)# banner motd "
* ....blah blah!
Switch(config)#interface range F0/1-48
etc.....
Is there any way to insert a variable inside a MLTCMD block?
-Jeff
You might try NOT using a CDATA section and sticking to < and >.  That said, I have not tried a variable embedded into a MLTCMD, so I cannot say if there are bugs there or not.
Note: works as-is in Netconfig templates.  The Template Center is a completely different engine.
I originally encountered the variable expansion problem while NOT using the CDATA tags.   I tried the CDATA method to see if that would resolve the problem.  The variable gets expanded outside the MLTCMD block either way.
Yes, I had noticed your conspicuous absense from the forum.  Nor problem, case opened.
I got the patch from TAC and it worked perfectly.  Thanks Joe!
anyone knows about the multi-line command functionality in Prime Infrastructure 1.2?
I didn't find anything in documentations or release notes of PI1.2. I tested it within Automated Deployment templates as it was mentionend in LMS, but it didn't work... 😞
best regards,
Daniel
This is definitely not available in PI 1.2, and I don't believe it will work in PI 1.3, either.
Thank you, Joseph.
It's a pity. I think it would be nice if such useful things like multi-line commans which were available in LMS before are also available in PI...
