IP Solution Center 4.1.1 MPLS VPN auto-discovery
delgadn
In IP solution center 4.1.1, some entities like "provider", "regions", "customers" and "sites" must be created in advance before running auto-discovery (v 4.1.1 no longer uses the file inventory.xml ).
After discovering all MPLS VPN's ISC provides a message saying that the MPLS VPN are invalid and must be associated with a customer.
When I try to perform the associaton between the VPN just discovered and the customer, none of the customer that I've created appear as an option. Only "DummyCustomer" appears.
Does anyone has any idea why the customers created before running the discovery doesn't appear?
Thanks in advance for your help.
prakashj
I'm using version 4.2.1 and facing the same problem as you are. When searching for some help saw your post. If you found the way out tell the procedure,
Thx,
