IPM 2.6 crash and work really bad.
Hi, I am using IPM 2.6 with a lot of problems. IPM often crash, and I have to restart the process manualy o sometimes restart the system. I noted also IPM sometimes just don't collect statistic for 4/5hours and after start again, by itself. Other times like I told you I need to restart it.
Some of you have this kind of experence. Can you help to resolve this issue?
Thank you really much. Antonello.
cisirunite
Maybe the problem is the one described here:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCdz13783
If so, the bug is not resolved in IPM 2.6.
The workaround is to launch a script file that restart the IPM processes at regular interval (for example every 4/6 hours o every day).
The commands are:
ipm stop
ipm start
