IPM Help
turfsniffer0
Hello we've been successfully using IPM 2.4 from Ciscoworks 2000 for last 8 years. We recently migrated to LMS3.1 and all is ok except I'm unable to get the new IPM to work. I think the problem is down to something I'm missing or doing wrong...so if i can describe what we do and then describe how IPM is currently configured perhaps some good soul can point me in right direction to resolving it?
We have a webserver sitting on a server in our DataCentre and it hold 8 pdf files of various sizes.
We configure 42 routers to send a http get request to access each of these files via IPM and we measure response times etc., Reports are generated twice weekly for our customer.
In IPM 2.4 we created 8 different HTTP operations naming them STM-A, STM-B, STM-C...and so on. Each one pointing to a pdf file on webserver on the operation. We create 8 collectors for each router - and each collector points to the HTTP operations created. (hope I'm making sense!!!). We do not use Targets. It all works.
Initially when trying to replicate the settings used in 2.4 i had serious problems getting it work in the new IPM.
First it would not let me create a collector without selecting a target (for this i created a ad hoc target for the server hosting the pdf files). It would create the collectors and i can see them, but it doesn't seem to send the the configurations to the routers (all 1720's btw - but they do work on the old IPM).
I think i got it working once but i couldn't get the reports working....its a nightmare thats been going on for the last few months and i just need some guidance. I can provide screenshots, logs etc., if required.
thanks in advance.
Steve
The IPM graphs now use Flash, so make sure you have Flash 9 or higher installed in your browser.  Given that the collectors are completing
successfully, you should see data points being drawn in the live Monitor graph.  It should take two minutes to see the first point.
8 Replies 8
Joe Clarke
Creating an adhoc target was the right thing to do.  The next thing to do is to create a custom HTTP operation which points to the appropriate relative URL on the server.  You can choose to use a custom DNS server, or just have IP SLA use the DNS which is configured on the device.  The final step is to define a Collector where you pick the device, the adhoc target, and your custom HTTP operation.  If this gets installed down to the source device successfully, but you are still unable to monitor the latency, post the output of "show ip sla conf" from the source device.
Thanks for taking the time to reply
After posting, I was able to manually create 8 tests and I could see the tests configured on the routers, but when trying to generate reports it shows nothing. I've also tried the Graph option in the Collector Management section IPM>Collector Mgmt>Collectors but it returns "No data available for the selected time period."
IOS version 12.2(40a) so I'm using the old RTR commands! Not sure if there's a compatability issue with this old IOS and the new IPM but I'm guessing its ok as the configs look exactly the same on the routers when using the old IPM.
PS_xxxxxx_Scarva#sh rtr conf
Complete Configuration Table (includes defaults)
Entry Number: 19573
Owner: ipm|CISCOVMS002
Tag: test_10x.x.x.x
Type of Operation to Perform: http
Reaction and History Threshold (milliseconds): 5000
Operation Frequency (seconds): 300
Operation Timeout (milliseconds): 5000
Verify Data: FALSE
Status of Entry (SNMP RowStatus): active
Protocol Type: httpAppl
Target Address:
Source Address: 0.0.0.0
Target Port: 0
Source Port: 0
Request Size (ARR data portion): 1
Response Size (ARR data portion): 1
Control Packets: enabled
Loose Source Routing: disabled
LSR Path:
Type of Service Parameters: 0x0
HTTP Operation: get
HTTP Server Version: 1.0
URL: http://10.x.x.x:80/OSPF-H.pdf
Proxy:
Raw String(s):
Cache Control: disabled
Life (seconds): infinite - runs forever
Next Scheduled Start Time: Start Time already passed
Entry Ageout (seconds): 3600
Connection Loss Reaction Enabled: FALSE
Timeout Reaction Enabled: FALSE
Threshold Reaction Type: never
Threshold Falling (milliseconds): 3000
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Verify Error Reaction Enabled: FALSE
Number of Statistic Hours kept: 2
Number of Statistic Paths kept: 1
Number of Statistic Hops kept: 1
Number of Statistic Distribution Buckets kept: 1
Statistic Distribution Interval (milliseconds): 20
Number of History Lives kept: 0
Number of History Buckets kept: 15
Number of History Samples kept: 1
History Filter Type: none
Entry Number: 38060
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-A.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Entry Number: 117946
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-E.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Entry Number: 127512
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-C.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Entry Number: 136790
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-F.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Entry Number: 186572
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-G.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Entry Number: 203012
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-B.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Entry Number: 203351
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-D.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Post the output of "show rtr coll".  If you click the Monitor button under Collector Mgmt do you see any graphs?  The reports and Graph button will take
much more time to populate with data.  The Monitor button will allow you to monitor your collector in real time.
Hi Joseph,
The monitor button displayed an empty graph, and i keep the window open for 30 mins or so but no tracking info.
I actually looked at the "sh rtr coll" command earlier and noticed that the collectors where going over the configured threshold (I left them on the default values). TestA seems to be ok on the default values. Although the others all showed that they were over the thresehold...so I reconfigured the threseholds for TestB operation and this seemed to work (in that I don't see any Overthresholds clocking up)...
Default for A,C,D,E,F,G
Timeout Value(msecs):  5000
Threshold(msecs):  5000
Sample Interval(secs):  300
Setting for B
Miscellaneous Settings
Threshold(msecs):  7000
heres the output of "sh rtr coll" after changing TestB operation. I guess the thresehold needs to be higher?
Entry Number: 19573
HTTP URL: http://10.x.x.x:80/OSPF-H.pdf
Start Time: 15:32:45.000 BST Fri Jul 16 2010
             Comps: 12             RTTMin: 13380
             OvrTh: 12             RTTMax: 15300
        DNSTimeOut: 0              RTTSum: 167000
        TCPTimeOut: 0             RTTSum2: 2326483870
        TraTimeOut: 0              DNSRTT: 0
          DNSError: 0           TCPConRTT: 105
         HTTPError: 0            TransRTT: 166895
          IntError: 0            MesgSize: 8255556
            Busies: 0
Entry Number: 19573
Start Time: 16:32:45.000 BST Fri Jul 16 2010
             Comps: 1              RTTMin: 13418
             OvrTh: 1              RTTMax: 13418
        DNSTimeOut: 0              RTTSum: 13418
        TCPTimeOut: 0             RTTSum2: 180042724
          DNSError: 0           TCPConRTT: 8
         HTTPError: 0            TransRTT: 13410
          IntError: 0            MesgSize: 687963
            Busies: 0
Entry Number: 38060
HTTP URL: http://10.x.x.x:80/OSPF-A.pdf
             Comps: 12             RTTMin: 545
             OvrTh: 0              RTTMax: 1181
        DNSTimeOut: 0              RTTSum: 10790
        TCPTimeOut: 0             RTTSum2: 10211200
          DNSError: 0           TCPConRTT: 107
         HTTPError: 0            TransRTT: 10683
          IntError: 0            MesgSize: 140424
            Busies: 0
Entry Number: 38060
             Comps: 1              RTTMin: 724
             OvrTh: 0              RTTMax: 724
        DNSTimeOut: 0              RTTSum: 724
        TCPTimeOut: 0             RTTSum2: 524176
         HTTPError: 0            TransRTT: 716
          IntError: 0            MesgSize: 11702
            Busies: 0
HTTP URL: http://10.x.x.x:80/OSPF-E.pdf
             Comps: 12             RTTMin: 10386
             OvrTh: 12             RTTMax: 11462
        DNSTimeOut: 0              RTTSum: 129836
        TCPTimeOut: 0             RTTSum2: 1405749174
          DNSError: 0           TCPConRTT: 106
         HTTPError: 0            TransRTT: 129730
          IntError: 0            MesgSize: 4785024
            Busies: 0
             Comps: 1              RTTMin: 10391
             OvrTh: 1              RTTMax: 10391
        DNSTimeOut: 0              RTTSum: 10391
        TCPTimeOut: 0             RTTSum2: 107972881
         HTTPError: 0            TransRTT: 10383
          IntError: 0            MesgSize: 398752
            Busies: 0
HTTP URL: http://10.x.x.x:80/OSPF-C.pdf
             Comps: 12             RTTMin: 8366
             OvrTh: 12             RTTMax: 8715
        DNSTimeOut: 0              RTTSum: 102440
        TCPTimeOut: 0             RTTSum2: 874604482
         HTTPError: 0            TransRTT: 102335
          IntError: 0            MesgSize: 3308772
            Busies: 0
             Comps: 1              RTTMin: 8156
             OvrTh: 1              RTTMax: 8156
        DNSTimeOut: 0              RTTSum: 8156
        TCPTimeOut: 0             RTTSum2: 66520336
         HTTPError: 0            TransRTT: 8148
          IntError: 0            MesgSize: 275731
            Busies: 0
HTTP URL: http://10.x.x.x:80/OSPF-F.pdf
Start Time: 15:32:46.000 BST Fri Jul 16 2010
             Comps: 12             RTTMin: 13358
             OvrTh: 12             RTTMax: 15263
        DNSTimeOut: 0              RTTSum: 166206
        TCPTimeOut: 0             RTTSum2: 2304442542
          DNSError: 0           TCPConRTT: 103
         HTTPError: 0            TransRTT: 166103
          IntError: 0            MesgSize: 8267256
            Busies: 0
Start Time: 16:32:46.000 BST Fri Jul 16 2010
             Comps: 1              RTTMin: 13273
             OvrTh: 1              RTTMax: 13273
        DNSTimeOut: 0              RTTSum: 13273
        TCPTimeOut: 0             RTTSum2: 176172529
         HTTPError: 0            TransRTT: 13265
          IntError: 0            MesgSize: 688938
            Busies: 0
HTTP URL: http://10.x.x.x:80/OSPF-G.pdf
             Comps: 12             RTTMin: 4769
             OvrTh: 11             RTTMax: 5883
        DNSTimeOut: 0              RTTSum: 65594
        TCPTimeOut: 0             RTTSum2: 359900562
         HTTPError: 0            TransRTT: 65491
          IntError: 0            MesgSize: 1856172
            Busies: 0
             Comps: 1              RTTMin: 4725
             OvrTh: 0              RTTMax: 4725
        DNSTimeOut: 0              RTTSum: 4725
        TCPTimeOut: 0             RTTSum2: 22325625
          DNSError: 0           TCPConRTT: 9
         HTTPError: 0            TransRTT: 4716
          IntError: 0            MesgSize: 154681
            Busies: 0
HTTP URL: http://10.x.x.x:80/OSPF-B.pdf
Start Time: 16:20:30.000 BST Fri Jul 16 2010
             Comps: 3              RTTMin: 1121
             OvrTh: 0              RTTMax: 1751
        DNSTimeOut: 0              RTTSum: 4020
        TCPTimeOut: 0             RTTSum2: 5640546
          DNSError: 0           TCPConRTT: 31
         HTTPError: 0            TransRTT: 3989
          IntError: 0            MesgSize: 334260
            Busies: 0
HTTP URL: http://10.x.x.x:80/OSPF-D.pdf
             Comps: 12             RTTMin: 10229
             OvrTh: 12             RTTMax: 11345
        DNSTimeOut: 0              RTTSum: 127819
        TCPTimeOut: 0             RTTSum2: 1362276531
         HTTPError: 0            TransRTT: 127713
          IntError: 0            MesgSize: 4578072
            Busies: 0
             Comps: 1              RTTMin: 10012
             OvrTh: 1              RTTMax: 10012
        DNSTimeOut: 0              RTTSum: 10012
        TCPTimeOut: 0             RTTSum2: 100240144
         HTTPError: 0            TransRTT: 10004
          IntError: 0            MesgSize: 381506
            Busies: 0
Hi Joseph,
This morning I changed the thresholds for all of the operations and I can now see data in the monitor graph for all of them. Thanks for helping there. My main issue though is still with generating reports.
After verifying that all the collectors are displaying realtime graphs I left it running for over an hour and tried to generate an hourly report. The report only had data for testA (which was working anyway)....it had no report data held for the remaining 7 collectors. I've attached a screenshot of the report.
Perhaps i should delete the collectors, recreate them and leave it running for awhile and try again. Actually I'll try that now....
cheers
Steven
I tried recreating the collectors and used a different router and appears to be the same issue. Test A gives results - other collectors don't. I guess i possibly need to revise the thresholds configured on the http operations created. I'm not sure i fully understand why though because the threshold on the old IPM are the same and work fine. I'll now toggle the threseholds and see if i can get the reports to pull data for the other collectors.
It seems that the reporting issue is seperate from the issue i was having with collectors. I can now see collectors and monitor stats but reports won't pull data for the majority of the collectors created.
