IR829GW - Disable LTE Failovertimer
AlexEM
Hello Community
I have a IR829GW Industrial Router and i'm trying to figure out a way to disable the default sim switch from slot 0 to 1(and vice-versa) on IOS
i am running a EEM and the sim switch failover timeout is messing with my script
My current config is this one:
controller Cellular 0
lte sim data-profile 2 attach-profile 2 slot 1
lte sim max-retry 0
lte modem link-recovery disable
If i issue no lte failover on the config mode, the system changes the timer to 3 minutes which is the default and minimum.
Is it possible to disable it?
I have already tried to issue the command lte failover 0 under controlller cellular0 config, but unfortunately the router doesn't accept the option.
I am running IOS Version 15.7(3)M4b, RELEASE SOFTWARE (fc1)
Kind regards
0 Replies 0
