Cannot set default interface on CBS350
Kvothe42
Community Member
Hi there,
I'm having troubles with my cli. If I want to restore an interface to its default state, my cli just says it's an unrecognized command.
What exactly is the problem here? Is there another way to reset the port config? Webinterface maybe? Havent found any solution that works.
Best regards
DanielP211
The default command is not present on the CBS. Your best option is to delete all the unnecessary config from the port manually.
****Kindly rate all useful posts*****
Kvothe42
Community Member
Is there at least a way of doing that using the cli? I did the most using the web interface and by now I'm not sure, what I did.
