is serial no longer in ccna
daniel4579329
can someone can confirm to me if the serial link topic is no longer in ccna
Martin L
Yes, frame relay and Serial interfaces are GONE !  That's good cause used to give me headache.
it has been removed officially from CCNA thru CCIE on RS side - for sure but frame relay was on Voice CCIE a bit last year, not sure if new CCIE Collab still has it.
Officially frame relay was replaced with DMVPN and it is tested in current cert versions.
Good luck on exam
Regards, ML
**Please Rate All Helpful Responses **
omz
about time they take it out along with frame relay .. :)
I am pretty sure its not in the new ccna ..
Martin L
Good luck on exam
Regards, ML
