Network Manager System deployment on Virtualization platform
Learnercisco
In my enviorment i want to delpoy thirdparty Network Managment system on Hyper-v for SNMP monitorning.
For high Availability i want to install Primay and Standby Netowrk Management  Server on Hyper-V Cluster.  we will use share storage for both servers(Primary/Standby) which hepls to achieve high availbility automatically between two Servers.
i wan to confirm which IP address Will be used by Netwok management system to recieve SNMP Trap ?
subnet: 10.10.10.0/24
1- Cluster IP Address : 10.10.10.1
2- Primary NMS IP address: 10.10.10.2
3- Secondary NMS Ip address:10.10.10.3
Note: one node will be active in Cluster.  please share your experience on the above.
thanks in advance.
kubn2
I believe you should use 10.10.10.1 because after that hyper-v cluster should forward SNMP messages to Primary active server (or standby in case Primary is not avaiable).
