Is there a tool I can use that shows IOS Level for my devices in "N-1, N-2 etc" format?
JeffLamp
As above - I need to create an excel report of all my devices that shows OS Level for each. If its the latest release it should say N, if its previous it should show N-1, 2 versions down should show N-2 etc etc
I have my devices and OS levels report so is there a sheet I can download that shows all OS versions and whether they are N-1 or N-2 etc?
thanks
Seb Rupik
Hi there,
No such list exists, you would need to create it yourself.
Also keep in mind that some platforms have multiple software trains available, sometimes one or more major versions and then multiple minor versions. Just look at IOS-XE. Also your version N maybe the latest (let say with the highest version number), but a release with no revisions would not be an ideal candidate for installation.
cheers,
Seb.
Thanks mate
