06-27-2024 01:18 AM
We are trying to locate a Cisco 2960 in a big building but we don't know where it is installed. There is a high possibility that it is installed under the floor so we are trying to look for ways on how we can locate it physically.
06-27-2024 04:00 AM
Nope.
However, if the 2960 is in a dusty surrounding the dust will cake around the hamster wheel and it will be noisy.
Go to the site when the area is devoid of people and just listen.
06-27-2024 04:03 AM
No. Depending on which model 2960 you have, some have very loud fans (2960X for example) and during boot up they sound like a jet engine. Suggesting you reboot if possible and walk around and you may be able to pick up some booting noise as the switch tests out all of its functions.
06-27-2024 04:43 AM
Indeed, those with variable speed fans often initially start with fans at high speed. Unfortunately, usually doesn't stay in high speed fan mode very long (just multiple seconds, I recall).
06-27-2024 09:48 PM - edited 06-27-2024 09:52 PM
The one installed is a 24P 2960L. Will give this a try. Thanks for the advice!
06-27-2024 04:03 AM
- No they can not make a sound (on command that is) ,
M.
06-27-2024 04:45 AM
No way to trace data cables to it?
06-27-2024 09:51 PM - edited 06-27-2024 09:52 PM
The cable from the distribution switch going to the 2960 switch goes through a conduit thus difficult to trace.
