Is there a way to show someone my (student/simple) packet tracer file for help?
Murphyp141
Is there a way to show someone my (student) packet tracer file for help? I tried to attach a file but it wouldn't let me. Thanks!
Hi @Murphyp141 ,
You can use programs like 7zip; winzip; winrar; etc. When you compress it the created file ends in .zip, .rar, etc. Then, you can formulate your doubt in this group and attach the file or some image of your topology and / or configuration.
5 Replies 5
luis_cordova
Hi @Murphyp141 ,
You just have to compress it before sending it.
How should I compress it...and which group do you think would be best to post my question in?
Thank you.
Hi @Murphyp141 ,
Thanks!
Hi @Murphyp141 ,
A pleasure to help you.
Remember to mark the help answer as solved, since that helps other users with a similar doubt.
