Hi Ansible at Ubuntu can access host router(R1/ip address 192.168.1.21). The playbook for ping to the router cannot work. In order to troubleshoot, I did the below tests where highlighted with green box are test commands. Among these tests, only -m ping show some error messsge. Is this reason for the failure of the playbook? Anyone can provide some suggestions for this issue? Thank you
