ISR 4461 17.0.04a Not Showing Logging In Console
TW80CJ5
Level 3
Level 3
Team,
I have a 4461 running 17.03.04a and it's returning odd snmp information when I show logging. I have configured logging console and term monitor.
However, when I issue the show log command, I get a mudslide of the following with no traditional logging statements in the console.
I have removed everything snmp from server, user, etc. but it still shows. I have cleared the log cache as well.
Here is the first 250 lines of whats returned on show log which is approximately 2700 lines:
#sh log
Syslog logging: enabled (0 messages dropped, 13255 messages rate-limited, 0 flushes, 1 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level informational, 2312985 messages logged, xml disabled,
filtering disabled
Monitor logging: level informational, 15020 messages logged, xml disabled,
filtering disabled
Logging to: vty866(71)
Buffer logging: level debugging, 9543498 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 134816 message lines logged
Logging to 192.168.2.45 (NTMGMT) (tcp port 514, audit disabled,
link down),
0 message lines logged,
0 message lines rate-limited,
0 message lines dropped-by-MD,
xml disabled, sequence number disabled
filtering disabled
Logging Source-Interface: VRF Name:
Loopback255 NTMGMT
Log Buffer (100000 bytes):
e.
CheckMIBView: OID is in MIB view.
SrCheckNotificationFilter: OID is included.
Sr_send_trap: trap sent to 192.168.2.45:162
SrV2GenerateNotification:Function has reached clean up routine.
31 Replies 31
Morning Richard...
I verified this morning that I still have my snmp traps configured and set up to informational ( IA requirement ). And yessir, you are correct, the original post was mostly about the snmp trap logging showing and not any type of logging with sh logging. So now I see hits on my ACL's which is what's desired.
So as for right now, things are good.
Thanks for the update. Glad to know that now you do have the desired behavior.
Rick
