isr4221 bandwidth limit issue
vidahostkenya
Greetings,
I just purchased ISR 4221 router and confirmed with tac that its a genuine product using the serial no.
My problem is that I have purchased 60mbps b/w from isp but when i connect this router, i can only get 30mbps, but when i connect a basic router dlink 605L, i can get the full b/w
Kindly point me in the right direction coz am a newbie in cisco stuff
regards
Mark Malone
docs say its starts at 35mbs and upgrade able to 75mbps , we use ASRs for 50mbps connections and 4331s for 10mbs - 30mbps
is it setup for the 75mb
https://www.cisco.com/c/en_in/products/collateral/routers/4000-series-integrated-services-routers-isr/datasheet-c78-732542.html
Table 4. Specifications of Cisco 4000 Series Integrated Services Routers
Technical Specifications
Cisco 4451
Cisco 4431
Cisco 4351
Cisco 4331
Cisco 4321
Cisco 4221
Aggregate Throughput
1 Gbps to
2 Gbps
500 Mbps to
1 Gbps
200 Mbps to
400 Mbps
100 Mbps to
300 Mbps
50 Mbps to
100 Mbps
35 Mbps to 75 Mbps
https://blog.router-switch.com/2016/11/the-new-isr-4221-the-new-cisco-dna-ready-platform/
With respect to performance, the ISR 4221 kicks it up a notch with throughput starting at 35 and upgrade-able up to 75 Mbps.
Red this post you waont get 60mbps if its not set for 75mbps
https://community.cisco.com/t5/switching/information-regarding-cisco-isr-4221/td-p/3359894
