07-20-2020 10:28 AM
I'm having issues updating the ASA software. I've tried to update my ASA software through ASDM, and TFTP through SSH. Any suggestions?
07-20-2020 11:39 AM
Not sure what is your upgrade path - some version required ASDM also required to upgrade -
So i always I prefer to do command Line - whatever way you like, using TFTP or Copy using USB.
07-20-2020 04:31 PM
07-21-2020 03:33 AM
follow the guide i have posted it has both upgrade process.
Make sure you using right interface to communicate with your TFTP Server.
To test you have reachablity before you go upgrade.,
copy your running config to TFTP Server see you able to see the configuration file in TFTP Server.
then place your images in the same place to download to ASA.
07-20-2020 11:58 PM
- What are the issues you are experiencing ?
M.
