Issue on WRT300N router's DHCP configuration
Markedward
Hello, I am having trouble with this type of router, where I have a set up of 4 wireless routers 8 end devices ( 4 laptops, 4 pcs) and 4 switches. The problem that I am having is that DHCP is configure on 4 wireless routers and all of them has ip address ranges ( router0 has 192.168.10.50-60, router1 has 192.168.200-210, router 2 has 192.168.100-110 and router3 has 192.168.150-160) with default gateways from router 0 to 3 being 192.168.10.1-4. With that configuration I also have 4 vlans, vlan 10-40 in which pc0-3 is connected to a switch that is connected to router0-4. Is it possible that pc0 only takes the IP address range of router0? I have attached the pkt file of my work and instructions. I hope I get a respond, Thank you! Pkt file link
marce1000
           - FYI : Community group for Packet Tracer project questions
  M.
