Issue with Logrot script
simon.bell
I was noticing that the log files were growing beyond the size defined even tho the job rotation schedule was set to run daily. When I manually run the job from cli I get the following messages:
Fri Nov 14 08:55:52 2008: INFO: Read variable backup_dir --> d:\log_files
Fri Nov 14 08:55:52 2008: INFO: Logfile = D:\PROGRA~1\CSCOpx\log\syslog.log, Backup File = d:\log_files\syslog.log
Fri Nov 14 08:55:52 2008: INFO: Not archiving D:\PROGRA~1\CSCOpx\log\syslog.log because it is not big enough.
file size = 428894481, conf size = 1073741824
Fri Nov 14 08:55:52 2008: INFO: Logfile = D:\PROGRA~1\CSCOpx\log\CSDiscovery.log, Backup File = d:\log_files\CSDiscovery.log
Fri Nov 14 08:55:52 2008: INFO: Logfile = D:\PROGRA~1\CSCOpx\log\dmgtDbg.log, Backup File = d:\log_files\dmgtDbg.log
Fri Nov 14 08:55:52 2008: INFO: Not archiving D:\PROGRA~1\CSCOpx\log\dmgtDbg.log because it is not big enough.
file size = 95940, conf size = 1048576
Fri Nov 14 08:55:52 2008: INFO: Logfile = d:\PROGRA~1\CSCOpx\log\ConfigMgmtServer.log, Backup File = d:\log_files\ConfigMgmtServer.log
Fri Nov 14 08:55:52 2008: INFO: Not archiving d:\PROGRA~1\CSCOpx\log\ConfigMgmtServer.log because it is not big enough.
file size = 28806819, conf size = 1073741824
Fri Nov 14 08:55:52 2008: INFO: Logfile = d:\PROGRA~1\CSCOpx\log\EPMServer.log, Backup File = d:\log_files\EPMServer.log
Fri Nov 14 08:55:52 2008: INFO: Not archiving d:\PROGRA~1\CSCOpx\log\EPMServer.log because it is not big enough.
file size = 423949228, conf size = 1073741824
Fri Nov 14 08:55:52 2008: INFO: Logfile = d:\PROGRA~1\CSCOpx\log\ani.log, Backup File = d:\log_files\ani.log
Fri Nov 14 08:55:52 2008: INFO: Logfile = d:\PROGRA~1\CSCOpx\log\CVDeviceSelector.log, Backup File = d:\log_files\CVDeviceSelector.log
Fri Nov 14 08:55:52 2008: INFO: Logfile = d:\PROGRA~1\CSCOpx\log\AnalyzerDebug.log, Backup File = d:\log_files\AnalyzerDebug.log
Fri Nov 14 08:55:52 2008: INFO: Not archiving d:\PROGRA~1\CSCOpx\log\AnalyzerDebug.log because it is not big enough.
file size = 551754, conf size = 1048576
Fri Nov 14 08:55:52 2008: INFO: Logfile = d:\PROGRA~1\CSCOpx\log\dbbackup.log, Backup File = d:\log_files\dbbackup.log
Fri Nov 14 08:55:52 2008: INFO: Logfile = d:\PROGRA~1\CSCOpx\log\ngdiscovery.log, Backup File = d:\log_files\ngdiscovery.log
Fri Nov 14 08:55:52 2008: INFO: Logfile = d:\PROGRA~1\CSCOpx\log\CSPortal.log, Backup File = d:\log_files\CSPortal.log
Fri Nov 14 08:55:52 2008: INFO: Not archiving d:\PROGRA~1\CSCOpx\log\CSPortal.log because it is not big enough.
file size = 38632, conf size = 1048576
However when I run logrog.pl -c the configuration is set to the following:
Number Logfile Name Number of Archives Max Size Compress
1. D:\PROGRA~1\CSCOpx\log\syslog.log 2 1048576 gz
2. D:\PROGRA~1\CSCOpx\log\CSDiscovery.log 2 1024 gz
3. D:\PROGRA~1\CSCOpx\log\dmgtDbg.log 2 1024 gz
4. d:\PROGRA~1\CSCOpx\log\ConfigMgmtServer.log 1 1048576 gz
5. d:\PROGRA~1\CSCOpx\log\EPMServer.log 1 1048576 gz
6. d:\PROGRA~1\CSCOpx\log\ani.log 2 1048576 gz
7. d:\PROGRA~1\CSCOpx\log\CVDeviceSelector.log 1 5120 gz
8. d:\PROGRA~1\CSCOpx\log\AnalyzerDebug.log 2 1024 gz
9. d:\PROGRA~1\CSCOpx\log\dbbackup.log 1 1024 gz
10. d:\PROGRA~1\CSCOpx\log\ngdiscovery.log 2 1024 gz
11. d:\PROGRA~1\CSCOpx\log\CSPortal.log 1 1024 gz
The conf file has the same settings so I'm not sure what the problem is... Any thoughts?
TIA,
Simon
Joe Clarke
These messages indicate that none of the log files configured are big enough for rotation (and most are 0 bytes or don't exist).
If you think this is an error, please post the output of a DIR showing the file size of one of the files not being rotated.
Volume in drive D is Data
Volume Serial Number is C894-61EE
Directory of D:\Program Files\CSCOpx\log
11/14/2008 09:09 AM
11/14/2008 09:09 AM
/////omitted small files////
11/13/2008 03:39 PM 112,989 license.log
11/14/2008 09:17 AM 124,177 EventFramework.log
09/04/2008 11:20 AM 204,711 DFMDeviceSelector.log
11/14/2008 09:17 AM 224,187 CTMJrmServer.log
11/14/2008 09:17 AM 226,903 NameServiceMonitor.log
11/11/2008 05:24 PM 234,437 ctm.log
11/11/2008 05:24 PM 237,034 DFMLogServer.log
11/13/2008 03:33 PM 244,359 ChangeAuditUI.log
11/11/2008 05:24 PM 261,114 PTMServer.log
11/14/2008 09:17 AM 460,259 EssMonitor.log
11/11/2008 05:22 PM 516,115 CampusOGSServer.log
11/14/2008 09:17 AM 535,037 configjobs.log
11/14/2008 09:47 AM 569,027 AnalyzerDebug.log
11/14/2008 09:47 AM 644,124 campusportal.log
11/14/2008 09:45 AM 705,497 wlseuhic.log
11/13/2008 03:33 PM 751,104 CSDeviceSelector.log
11/14/2008 08:06 AM 764,018 invreports.log
11/14/2008 09:47 AM 779,973 psu.log
11/14/2008 09:00 AM 827,407 smtp.log
11/14/2008 09:17 AM 971,560 rme_ctm.log
11/12/2008 12:05 PM 1,397,144 RMEOGSServer.log
11/07/2008 10:17 AM 2,148,277 netconfigclient.log
11/11/2008 05:08 PM 2,172,220 wlseuhic.log_backup
11/13/2008 03:01 PM 2,281,418 RMEHome.log
11/14/2008 08:26 AM 2,377,355 IC_Server.log
11/06/2008 03:56 PM 2,507,950 dcrclient.log
11/10/2008 11:16 AM 2,818,721 RMEDeviceSelector.log
11/11/2008 09:50 PM 3,093,266 SyslogCollector.log
11/12/2008 10:45 AM 4,045,785 cjp.log
11/14/2008 09:18 AM 4,079,432 RMEPortlets.log
11/14/2008 08:06 AM 4,185,385 cri.log
11/14/2008 02:01 AM 5,020,551 UTMajorAcquisition.log
11/14/2008 09:33 AM 5,137,977 EDS.log
11/13/2008 03:33 PM 5,354,742 ICServerUI.log
11/11/2008 05:14 PM 5,498,025 rme.log
11/14/2008 08:07 AM 6,751,542 NetShowClient.log
11/14/2008 09:43 AM 7,536,956 EssentialsDM_Server.log
11/14/2008 09:17 AM 7,835,072 dcmaclient.log
11/14/2008 08:36 AM 7,873,149 swim_debug.log
11/14/2008 09:43 AM 8,163,301 dcmaservice.log
11/13/2008 05:11 PM 9,273,371 SyslogAnalyzerUI.log
11/14/2008 09:41 AM 9,771,458 EssentialsDM.log
11/14/2008 01:43 AM 10,240,011 IC_Server.log.1
11/13/2008 05:33 PM 10,240,033 dcmaservice.log.2
11/13/2008 06:12 PM 10,240,092 dcmaservice.log.1
11/14/2008 01:28 AM 10,240,210 IC_Server.log.2
11/14/2008 09:09 AM 14,604,727 ani_debug.log
11/13/2008 06:37 PM 28,806,819 ConfigMgmtServer.log
11/14/2008 09:46 AM 34,058,072 NOSServer.log
11/14/2008 09:44 AM 229,202,511 ani_debug_new.log
11/14/2008 09:47 AM 368,077,218 jrm.log
11/14/2008 09:44 AM 423,953,818 EPMServer.log
11/14/2008 09:48 AM 432,069,582 syslog.log
134 File(s) 1,691,650,895 bytes
4 Dir(s) 80,313,647,104 bytes free
Logrot appears to be correct. Your syslog.log is ~ 432 MB, but the configured logrot size is 1 GB. The same 1 GB size is also configured for ConfigMgmtServer.log and EPMServer.log.
The logrot file sizes are specified in kilobytes.
ah... you're right. For some reason I was thinking it hit the file @ 10mb.
Sorry for the misunderstanding.
sb
