Issue with VTP *** MD5 digest checksum mismatch on trunk: Po1 ***
jose-rangel1
Anybody can help me with this issue on VTP?
7 Replies 7
Double check the password you use in both SW
MHM
Helo @jose-rangel1 ,
ensure the VTP domain is configured identical throughout your network. The MD5 digest caries the the VTP password used to authenticate update messages between switches.VTP takes into account the VTP domain when calculating the MD5 digest.
Hope it helps.
Regards, LG
*** Please Rate All Helpful Responses ***
M02@rt37
Hello @jose-rangel1
On your switches do:
Switch#show vtp password
VTP Password:xxxx
Check password. Must match. Test with an "easy" password without special characters.
Best regards
Hey, I check the password.
Trap generate is one enable and other disable' match it
MHM
Done.
