Issues with IOS upgrading a ISR 4331 that is not accepting the ROMMON upgrade
Ideal Networks
I am currently in the process of trying to upgrade the IOS of a ISR 4331 currently running the following:
Cisco IOS XE Software, Version 03.13.04.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S4, RELEASE SOFTWARE (fc3)
I was under the impression that due to the version I'm trying to get install that i would need to upgrade the ROMMON beforehand with say this pkg. - isr4300-rommon.162-1r.pkg
I have then followed the following:
Pre Check-
RTR-01#show rom-monitor r0
System Bootstrap, Version 15.4(3r)S5, RELEASE SOFTWARE
Copyright (c) 1994-2015 by cisco Systems, Inc.
RTR-01#upgrade rom-monitor filename bootflash:isr4300-rommon.162-1r.pkg all
WR and then issued a reload
however when i run the - show rom-monitor r0 the output remains the same as above.
I have seen some posts which are quite confusing they seem to imply that if I upgrade the image to anything prior to 16.4.1 then I need to to upgrade rommon, so my question is if my target version is isr4300-universalk9.16.04.03.SPA.bin (Everest) then I dont need to take any action with a ROMMON PKG as this will be taken care of with the bin that is on or above 16.4.1?
Hope this makes sense?
Leo Laohoo
Do not use 16.12(1r):  CSCvr18589
Instead, upgrade to 16.12(2r).
Post the complete output to the following command:
sh platform
Hi originally I tried to use:-isr4200_4300_rommon_1612_2r_SPA.pkg but got the same output after the reload:-
Show platform is:-
RTR-01#show platform
Chassis type: ISR4331/K9
Slot Type State Insert time (ago)
0 ISR4331/K9 ok 21:33:46
0/0 ISR4331-3x1GE ok 21:32:45
1 ISR4331/K9 ok 21:33:46
R0 ISR4331/K9 ok, active 21:33:46
F0 ISR4331/K9 ok, active 21:33:46
P0 PWR-4330-AC ok 21:33:22
P2 ACS-4330-FANASSY ok 21:33:22
Slot CPLD Version Firmware Version
0 15030325 15.4(3r)S5
1 15030325 15.4(3r)S5
R0 15030325 15.4(3r)S5
F0 15030325 15.4(3r)S5
