Issues with terminal server on Cisco 4331
User24571
I have problem with my termianal server on Cisco 4331 (+ NIM-16A) Can you tell me what the correct configuration should look like?
I don't send output, because I want to compare and correct my errors :)
marce1000
      - Can you also tell what the problem is ?
M.
My problem is that when connected to a remote device, I see a message:
"% Unknown command or computer name, or unable to find computer address"
every moment...
Example:
Router1# RemoteSW
Trying RemoteSW (10.0.12.1, 2001)... Open
RemoteSW#
RemoteSW#
RemoteSW#               ^
 - The command you typed is not understood. Type a ?  (only) on the command prompt to get a list of available commands and or to get the correct syntax of the intended command.
M.
Ok, but I don't issue any commands.. I don't do anything.. this message appears..
any ideas?
