Java Error
ednelson
Community Member
I have a 2811 Router with IOS 12.4(3e) and SDM 2.3.1. Every time I exit the SDM I get an Unxpected error detected by Hotspot Virtual Machine: Exception_Access_Violation (0xc0000005). I have Java jre 1.5.0-b64 installed on PC running windows XP Pro. Why am I getting this error and are there any fixes?
thanks
ahmednaas
Level 8
Level 8
It seems that much of Cisco's java based software doesn't like the latest JRE releases. You might have to downgrade your JRE to 1.4.x or 1.3.x.
