Java Problem.........LMS 2.5
parvs_cmc
I am facing problems with Campus Manager.Whenever I try to open any application like Topology Servies..etc Java window comes up with message "Initializing vbjorb capabilities for CiscoWorks...
checking properties
vbjorb.jar present in C:\PROGRA~1\Java\JRE15~1.0_0\lib\endorsed
downloading vbjorb.jar.....
This may take few minutes .. & application doesn't open.Please see the attachment.
How can I solve this Problem.....I am new to LMS........Please help
miheg
Level 9
Level 9
Campus doesn't like other java's then it's own.
Uninstall them and then install the one your LMS wants.
Michel
5 Replies 5
miheg
Level 9
Level 9
Michel
The LMS 2.51 update does allow for new JRE versions.
The CW download section provides a resent one.
Bas Kokken
David Stanford
You can also try going in the browser to Tools -- Internet Options -- Advanced -- Java (Sun) and uncheck the option to use Java 1.4.2 and then restart
I've had a few cases where this was the cause of the problem.
David Stanford
Also, forgot that you can try this:
Replace /usr/j2re1.4.2_08/lib/endorsed/vbjorb.jar with the one in either of the following files:
/opt/CSCOpx/www/classpath/vbjorb.jar
(Size: 2,945,954)
/opt/CSCOpx/campus/www/classpath/vbjorb.jar
(Size: 2,945,954)
Sorry, windows instructions:
Replace C:\Program Files\Java\j2re1.4.2_08\lib\endorsed with the one in either of the following files:
c:\Program Files\CSCOpx\www\classpath\vbjorb.jar
(Size: 2,945,954)
c:\Program Files\CSCOpx\campus\www\classpath\vbjorb.jar
(Size: 2,945,954)
