Java problem with Topology Services
muratayas
Community Member
i have a problem with the topology services. When i start it then he want install a plugin but it not works.
And when i click the button for install the plugin then come this
but the the Manuell Install button show me how i must install this Java but its not works 😞
can anybody help me
regards,
murat ayas
Joe Clarke
First, you appear to be using a non-US English locale on your client.  This is not supported.  Only US English and Japanese locales are currently supported.  Next, what version of LMS do you have?
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
