Kiwi syslog
tung
I have the following configured on my router but nothing display in my kiwi syslog. I'm new to this so please help. Thanks
logging buffered 4096 debugging
logging console informational
logging monitor informational
logging facility local3
logging source-interface FastEthernet0/0
logging 10.17.84.51
These types of events do not generate syslog messages. A config change, on the other hand, does generate a message. If you need a comprehensive list of available syslog messages, you can use the system error messages guide for your release of IOS. For example, for IOS 12.4, see http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124sup/124sms/index.htm .
If you define ACLs, and configure them for logging, you can get syslog messages for traffic that matches. However, this can be burdensome to the device if a lot of traffic is passing through it.
5 Replies 5
nhabib
Level 9
Level 9
Check on your Kiwi syslog server to make sure it is listening on local3
The default setting on Cisco devices is local7
You are right but for some reason it only logged whenever I do a changed on my router. It doesn't log anything else. Please help. Thanks
What do you want it to log? What events are occurring on your device that you think should be logged, but are not being logged?
Example like traffic going in and out of the outside interface and log anyone login to the router (currently only log when you make changes). Thanks
