L2TP in GNS not working
Hello Everyone,
I can't seem to find what is the problem with my config. I get my client to connect to the LAC, the virtual iface connection is established and is visible from the sh users command. However, the connection doesn't even reach the LNS.
Can you please browse my config and let me know what is the problem?
Thank you in advance!
Exert; full runnig configs attached as .txt
CE1 = Client
CE1#sh users
Line User Host(s) Idle Location
* 0 con 0 idle 00:00:00
Interface User Mode Idle Peer Address
Vi2 PPPoE 04:28:17
CE1#sh run int di1
Building configuration...
Current configuration : 204 bytes
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication chap callin
ppp chap hostname USER1
ppp chap password 0 123456
end
CE1#
LAC#
LAC#sh run | s user
username USER1 password 0 123456
LAC#
LAC#
LAC#sh run | s vpdn
vpdn enable
vpdn search-order domain
vpdn-group 1
request-dialin
protocol l2tp
domain asd4khd.org
initiate-to ip 80.156.137.244 priority 1
local name LAC
l2tp tunnel password 0 qweasd
l2tp tunnel receive-window 1024
LAC#
LNS#sh run | s user
username LAC password 0 qweasd
LNS#sh run | s vpdn
vpdn enable
vpdn-group 1
accept-dialin
protocol l2tp
virtual-template 1
terminate-from hostname LAC
source-ip 80.156.137.244
local name LNS
LNS#
Hi Guys,
I'm happy to inform you that we've found the solution.
There needs to be an IP pair between LAC and LNS (on this topology at least).
The LAC DOESN'T need to contain the usernames, only the LNS needs to.
You need to add the domain to the CHAP user name within the LNS username config
of you use domain-search on the LAC.
After correcting these my dialer finally got the IP address from the LNS pool and thus the connection
is working.
Dialer1 77.0.0.1 YES IPCP up up
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
80.0.0.0/32 is subnetted, 1 subnets
C 80.156.137.244 is directly connected, Dialer1
77.0.0.0/32 is subnetted, 1 subnets
C 77.0.0.1 is directly connected, Dialer1
S* 0.0.0.0/0 is directly connected, Dialer1
CE1#
