L3 Switch script to shutdown a port based IP reachability
oguarisco
Level 3
Level 3
Hello all,
I would like to know if using EEM I can shutdown a Gigabit interface based on IP reachability of the remote neighbor via ping?
And no shutdown when the IP reachability is reestablished? I'm Using IOS-XE
I ask this because I've a L2 connection which is not directly end-to-end but it have some network component (DWDM) in the middle for signal regeneration.
The provider of the DWDM circuit confirm that the signal is NOT end-to-end so in case there is a failure ine the circuit the interfaces of the L3 switches won't go down and the traffic is still routed on this path since on the Routing table he routes are still present also if the remote neighbor is not reachable
should I Use the track with the event manager applet IOS commands???
Many Thanks
Saluti
2 Accepted Solutions
Hello
EEM is a nice feature and combine this with ip sla would provide you with the result your seeking
Attached is a sample config
Res
Paul
Kind Regards
Paul
Hello
Glad I could help, would you be so kind and rate any posts applicable and mark answered so it will be of assistance to future postiers
Res
Paul
Kind Regards
Paul
6 Replies 6
avayner
I would recommend looking at feature based capabilities before implementing things with EEM... This way it would be easier to support etc...
The functionality you are asking for should be available on your platform (I assume you are on ASR1K as you are mentioning IOS-XE). You should look at BFD...
Here are a few references:
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bfd/configuration/xe-3s/irb-bi-fwd-det.html
You mentioned static routes, so maybe this is also relevant:
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bfd/configuration/xe-3s/irb-xe-3s-book_chapter_01000.html
Arie
Hello Arie,
Thanks for the information...actually I'm on a cat4500X.
Is BFD a standard protocol? Which could be used also with non Cisco devices???
Regarding EEM I'll definitively take a look at the feature, maybe I'll find something useful there ,-)
Omar
Omar,
BFD is an IETF RFC defined by a number of RFCs (RFC5880-5884) and it is widely implemented. Most vendors should support it today.
For 4500X take a look here:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst4500/15.1.2/XE_340/configuration/guide/bfd.html
Arie
Hello
Res
Paul
Kind Regards
Paul
Hello Paul,
Thank a lot... I remember correctly that you can do it with EEM but I've forgot the name of the feature (IP SLA)
Thanks again!!!
Omar
Hello
Res
Paul
Kind Regards
Paul
