Licensing Problem
Mansoor Hafeez
Greetings
I have installed the LMS2.5 couple of months before along with the license key.
Couple of days before I tried to install the VMS for IPS on the same Machine. Somehow the installation was unsuccessful and I had to uninstall the VMS from the system. Since uninstall of VMS now whenever i open any application like RME, CM,DFM etc i get the message that I am running the evaluation software which will expire after 90 days.
If I look into the licensing info window under Common Services, the licensing for every product is showing as never expired.
I have tried to update the licensing file again but all of the time I get the message of 90 day evaluation.
Does anyone have idea what is going on?
Mansoor
nhabib
Level 9
Level 9
If you are on Windows, open a DOS shell and issue the command:
pdterm LicenseServer
Go to CSCOpx\etc\licenses
Delete all *.lic files (NOTE: LMS***.lic file should not be copied to this
directory directly. If it is there, move it to some other directory.)
Back to the DOS shell and issue the command:
pdexec LicenseServer
Update the LMS**.lic file from the UI from Server->Admin->Licensing
(The LMS**.lic should be in some other directory other than $NMSROOT/etc/licenses and must have read permission for casuser)
Close all the browser sessions and open a new browser and launch the CiscoWorks and check for the popup message.
If you are on Solaris:
cd /opt/CSCOpx/bin
./pdterm LicenseServer
cd /opt/CSCOpx/etc/licenses
rm *.lic files
(NOTE: LMS***.lic file should not be copied to this directory directly. If it is there, move it to some other directory)
cd /opt/CSCOpx/bin
./pdexec LicenseServer
